15 years agoEthernet problem turned out to be a memory / DMA problem
So I have spent a couple weeks trying to troubleshoot Ethernet functionality on my custom board. I finally isolated the problem last night. Ethernet data is getting into the FPGA just fine. I can ...
15 years agoI know it is a bit obvious - but are you sure you've got the buffer addresses used by the ethernet dma correct, and the cpu cache not interfering with the reads?
