17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
15 years ago --- Quote Start --- Great ! Is this driver update for NU or noMMU ? Hoping that the patch will reach the main stream, -Michael --- Quote End --- The patch is against unstable-nios2mmu (2.6.37) but I think it should work for both, but I've only tested it on my tree, which has some other modifications, such as the mentioned hacking out of checksum code. I'm sending the current version to nios2-dev, but I'll probably need to break it up and test against unstable before it can get accepted. And it looks like I'll need to update and move to device tree before I can do that.
