17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
15 years agoDo you have the same problem with UDP? Is it really corruption, or lost packets?
I had a problem a while ago with slow TCP connections on both ucOS and eCos, where a lot of TCP packets were lost, causing lost of retransmissions and a very low speed. I found out that the problem came from the fact that the IP stack was too slow to process the received packets, the TSE FIFO became full and some packets were lost. The workaround I found was to increase the TSE receive FIFO so that it was higher than the TCP window size, but this only works if you have only one active TCP connection. I'd be interested to know if there are better solutions around...
