17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
15 years agoIs this just a problem with speed, or is it worse? I am seeing actual data corruption on inbound packets using TCP. I can see it running iperf. I have to slow way down to eliminate this. Granted, I am running with only a 1K cache and a non-optimized kernel. I am in the process of fixing these things, but I don't think I should ever see corruption when using TCP...?
Thanks, Van
