17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoIf the hardware can't be modified, the best option supposedly would be not to use Linux and/or not to use IP. There are other IP stacks then the Linux stack. Consulting another Altera Forum and/or an Altera sales FAE might bring up some solutions.
If you don't use IP (much faster) you would need to write a driver for your propriety protocol for the Mac. -Michael
