17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoBenjamin, what exactly are you trying to accomplish ?
Three factors are slowing down your transfer rate: Linux, UDP/IP, and NIOS. Do you really need Linux ? There are other options. AFAIK you even can do a TCP/IP stack in Hardware with an FPGA.. If you do need Linux, you might run Linux on one CPU and provide dedicated hardware (perhaps including a CPU) for the communication stack. Do you really need UDP ? Other options include "naked" Ethernet, Firewire and USB3. Those provide a much smaller protocol overhead. Do you really need NIOS. Of course NIOS is a very viable option when you want to include a CPU in an FPGA. Do you really need an FPGA ? Do you really need a "single chip" design ? There are by far faster CPUs done in real Hardware. -Michael
