17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoI agree. With Nios II running Linux/uClinux, this will be a big challenge. There is, however, a non-Linux UDP offload example (http://nioswiki.com/index.php?title=exampledesigns/nios2udpoffloadexample) on the Wiki that hits GbE line speed rates.
I feel that this is the best way to do this sort of thing with soft core processors. Regards, --slacker
