17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years ago --- Quote Start --- Will I never achieve that throughput using UDP, Nios II and the TSE core? --- Quote End --- Supposedly not with a NIOS CPU (there are special CPUs that are designed to be able to do this in router applications such as Ubicom 7K) and especially not with a Linux IP Stack (there are dedicated "Zero-Copy" stacks and special OSes that maybe can do this. Example: Ubicom again) (Beware: Ubicom provides nice cheap chips but the development tools are rather expensive.) -Michael
