17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoI suspect the linker script is generated in the the "make vendor_hw_select=..." process. I haven't turned my linux box on in months, so I can't verify.
As a side note, if anyone is interested in performing a test with a harware CRC calculation IP, implemented as an avalon slave, I am open to writing the verilog code. It would only take me an hour or so. That is, of course, if the TSE does not already implement it in hardware.
