17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoAs in the NIOS uCLinux formus, there have been requests for faster TCP/IP performance already multiple times in the past, I feel it would be viable to include a configuration setting in the Kernel building options for appropriate use of internal memory for the critical code and/or data sections.
Of course this should be done for the MMU enabled distribution, as same will be used in the future supposedly nearly exclusively. (And of course only if the performance gain is decently proven.) Should we at least add a paragraph in the "ToDo" section of the NiosWiki ? -Michael
