17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoSorry if this is too generic, but it might point you onto topics you might not have already addressed.
If I recall correctly, on the old niosforum, a guy had a whole slew of things he did to make pretty radical improvements. Like hippo suggests, reducing the memory latency is a good way to improve the performance. Putting the data buffers in SRAM or SSRAM rather than DDR, and several key pieces of network code, hels alot. I can't recall exactly how you specify certain files to be compiled into a specific portion of RAM, but there is a way to do it. Also if the CRC checksum algorithm is done in software, a hardware implementation helps. I recall one post where he was getting around 60 Mbits/sec on the opencores 10/100 core with udp. Another with 10/100/1000 got over 100 Mbits/sec. If it can be believed, this should be your expectations. Edit: I am not sure this was under uClinux though.
