17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoYou probably thought about it already, but are you sure that you compile the kernel and code with full optimisations? The code generated with -O 0 can be quite slow...
