17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoThanks for the suggestion hippo. Indeed the cache was set to the minimum. Setting it to 16+16k got the 1K time down to 420us (19Mbit/s) so that's definitely better but I'm still looking for ways to improve it. I'm also doing some receive tests and that's looking even worse so far.
