17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoI did mention I'm doing some tests with TCP as well, but all the above results are with udp. With UDP, there is over 500us of overhead per message, most of which by my understanding is not due to copying the buffer.
