17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoSo you found that UDP is a lot faster than TCP, and you found that copying overhead is not the major problem with TCP ?
Of course UDP does impose less overhead than TCP but I did not think that this would be that important. Thanks for letting us know ! -Michael
