17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
17 years agoThis already has been discussed here several times. Out of the box, Linux is versatile, but not fast with TCP/IP. NIOS is a quite slow processor. So I don't think that you will achieve much more throughput on such a system without introducing special "router" stuff like the "Zero-Copy Stack" (which needs a special Ethernet driver).
-Michael
