Etherenet TCP/IP server for Arria V board
I was able to solve the compile error I got by adding an interval timer to my nios II system, but now I'm getting another error when I compile:
In file included from ./drivers/inc/iniche/altera_eth_tse_iniche.h:36:0, from ./drivers/inc/altera_eth_tse.h:36, from alt_sys_init.c:65: ./drivers/inc/iniche/ins_tse_mac.h:34:27: fatal error: altera_msgdma.h: No such file or directory Note: I am running quartis and eclipese-nios on a scientific linux machineHi,
I am trying to implement triple speed ethernet in nios processor using modular scatter gather dma (msgdma) controller. I have build the qsys. For memory i have used ram. I have called 2 msgdma one for receiving in streaming to memory mode and one for transmitting in memory to streaming mode. I have done the interconnections in qsys platform and generated the HDL successfully. The sopcinfo file is also generated. Using this sopcinfo file i tried to generate the bsp. The bsp generates but when i try to build the bsp project in eclipse the build fails. It says that " fatal error. altera_msgdma.h. No such file exists."
I am using Quartus 18.1. I cannot downgrade to lower version as i have progressed a lot in 18.1 and now cannot migrate to a lower version because of dependency issues.
Actually this file is missing in alt_avalon_tse.h. The altera_msgdma.h exists in the installation folder of quartus 18.1 in c drive. But some how when i try to build the bsp it doesn't pick that file and throws the above mentioned error. I have tried to manually move altera_msgdma.h and altera_msgdma.c file into the incude and source file of the driver folder of the project file. After doing this the bsp builds, but the actual project build fails.
I am not using linux
Kindly guide
Av
