20 years agoeth0 not found
I am trying to bring up the Ethernet interface of my DE2 board, but it keeps me showing "SIOCSIFADDR: No such device" when I ifconfig it.
I followed every step of the tutorial and I am using the uClinux-dist-test-20060511.tar.bz2 with only the uClinux-dist.diff.gz patch. Is there something wrong with this kernel? I am starting to think it could be a hardware problem, cause my board's ethernet connector leds do not turn on when I plug the network cable. Following are the system messages:Uncompressing Linux... Ok, booting the kernel.
Linux version 2.6.16-uc0 (root@localhost) (gcc version 3.4.6)# 7 PREEMPT Thu Aug
3 03:53:27 Local time zone must be set--see z
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 003F0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6600k/8192k RAM, 0k/0k ROM (1173k kernel code, 324k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80400830 (irq = 1) is a jtag_uart
dmfe_probe:eth0, 50000 Khz Nios
dmfe_probe: eth0 VID: 0x2B2A2928 .ne. 0x90000A46
NET: Registered protocol family 2
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 224k freed (0x932000 - 0x969000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
mount failed: No such file or directory
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: ifconfig lo 127.0.0.1
Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/> ifconfig eth0 192.168.254.11
SIOCSIFADDR: No such device Thanks11 Replies
thank you for your helpful answers.
as you said, the LAN91C111 is not well, the reset signal always high, so it's not initial, now it's work well
