13 years agoerror with NIOS2
Hello Friends , My design contains one .sof file and the board i'm using is TR4230 (Terasic) board. This people will give the gui kind of flash program. And by using this wind...
13 years agoHmm that is strange because that 19104600 node is the Nios II JTAG debug module. That information means:
1) USB-Blaster [USB-0] <--# 1 is your cable number, you can also identify the cable using "USB-0" 024090DD EP4SGX230 <-- this is the device that was found hanging off the programing cable Node 0C006E00 JTAG UART# 1 <-- JTAG UART with an instance ID of 0 Node 19104600 Nios II# 0 <-- Nios II JTAG debug module with an instance ID of 0 Cable 1 and Nios II JTAG debug module instance ID 0 should be the defaults when you call nios2-flash-programmer from the command line. Perhaps you can try passing in the cable number and instance IDs into nios2-flash-programmer to see if it behaves differently. If I remember correctly the flags should be -c 1 -i 0
