16 years agoError while trying to use RS232 port on DE2 2c35 running uClinux
Hi all, I try to use RS232 port on my DE2 board to communicate with my device (magnetic card reader). But when I try to use the command "cat test.txt > /dev/ttyS0", the console appears with "/de...
16 years agoHi Tien,
You have to be carefull with this command "cat test.txt > /dev/ttyS0", use microcom instead. You will find it in the application selection of the make menuconfig. command will be : microcom -s 9600 /dev/ttyS0 with 9600 the baud rate of your serial connexion.
