15 years agoerror while building project: during creation of system.h file
hi everyone, am trying to run some software demo files on nios ii, am getting following error messege when i try to build project. make -s all includes Creating generated_app.mk... ...
15 years agoHey
Clean the project and rebuild it..Dont forget to clean the .metadata..Everything and then build again.I guess this is the problem of the tool.I face it many times but there is no explanation of it and is the only solution.After 4 or 5 times u will get it working for sure..And if you are a Windows user keep in mind to shut down it atleast once in a day.It may also be a problem.
