11 years agoError when building project in eclipse
Hello, I am having problem when I build project in eclipse. I already build the Application and BSP Project. I right click the CRC_Accelerator_bsp software project and choose build project to buil...
11 years agoDo you read your post before posting?
Do this: Generate the BSP to update the Makefile, and then build again. To generate from Eclipse: 1. Right-click the BSP project. 2. In the Nios II Menu, click Generate BSP. To generate from the command line: nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory>
