11 years agoError when building project in eclipse
Hello, I am having problem when I build project in eclipse. I already build the Application and BSP Project. I right click the CRC_Accelerator_bsp software project and choose build project to buil...
11 years agoI get this output in the console:
**** Build of configuration Nios II for project Hello_World2 **** make all Info: Building ../Hello_World2_bsp/ make --no-print-directory -C ../Hello_World2_bsp/ Makefile not up to date. C:/Users/Nanthini/Desktop/CRC_Acceleration_Example_Design/CycloneII/CRC_System.sopcinfo has been modified since the BSP was generated. Generate the BSP to update the Makefile, and then build again. To generate from Eclipse: 1. Right-click the BSP project. 2. In the Nios II Menu, click Generate BSP. To generate from the command line: nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory> make[1]: *** [public.mk] Error 1 make: *** [../Hello_World2_bsp/-recurs-make-lib] Error 2 **** Build Finished **** It says "Launching New Configuration" has encountered a problem. Downloading ELF process failed. And how do I see if I included the system ID block in my SOPC/qsys design?
