16 years agoError: The input line is too long.
I am using Nios II 9.1 Software Build Tools for Eclipse (SP1). I have a large number of source files to add to my IDE project. At some point after adding many source files I get this error when t...
16 years agoI have resorted to manually editing the Makefile every time I add or remove source files within the Eclipse IDE. What a PITA :mad: !
warning: Keep a backup copy of the Makefile around (or check it into a revision control system) because I have found that sometimes all sources will be deleted from the Makefile. If this happens and you don't have a backup you will have to recreate the source list from scratch :eek: !
