14 years ago
Error "Pausing target processor: not responding." with VIP
Hi All
I 'm in the last year of my master in microelectronic and I make a project with image processiong.
I try to use this VIP:
Clocked Video Input
Color Plane Sequencer
Frame Buffer
two Clocked Video Outup, one for the 800x600 and the other for the VGA.
I use the tPad Eval Board.
I have also still open the Standalone Programmer for JTAG connection, but I became still this Error Message after compilation in Nios:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and trying again: FAILED
Leaving target processor paused
In Nios I try first the simple hello_world software...
Could anywhere help me please.
Thanks alot
Antonio
    Did you upload an FPGA image with a Nios CPU in? Is it an example design or a custom one?
    If it's a custom one, check that the clocks are working and that you connected the reset signal properly (the reset_n input of the SOPC component is active low).
    This problem normally has something to do with reset problems..
    Thanks for the fast answer...
    I could fix the bug, I changed the CPU performance on "e", now my custom design works well...
