10 years agoError in Including Altera libraries file into uClinux
Hi everyone, Recently I'm finally successfully booted uClinux into DE2-115. Now I want to change a project from using Nios II Software Build Tools for Eclipse into uClinux. Before I do this, I woul...
10 years agoHi,
and what is the difference between nios2-linux-gnu-gcc an nios2-linux-uclibc-gcc command? I refer to many resources, but some use nios2-linux-gnu-gcc and some use nios2-linux-uclibc-gcc to compile the program. Then flat format file created will be put into ~/uClinux-dist/romfs/bin before make image. Jun Mun
