SONG
8 years agoError from the tutorial of Generating and Compiling Cyclone V Preloader
Hi, I have an Error from the tutorial of Generating and Compiling Cyclone V Preloader. the error message is here ------------------ C:\intelFPGA\18.0\embedded\host_tools\mentor\gnu\arm\baremetal\...
Abe
8 years agoThe main issue may be due to permissions as the error describes:
" cannot open map file u-boot-spl.map: Permission denied"
Check if your working / code folders have requisite permissions - read/write before executing the make command. Also verify that you are not referencing another user's workspace which might be in read-only mode.
Did you run the command with super-user/root privilages (su make/ sudo make) try running it that way and check.
