15 years agoError: Connected system ID hash not found on target at expected base address
Hello, Usual sentence first: I'm fairly new to FPGA programming, so bear with me. I tried to follow the Nios II Hardware Development Tutorial (version 3.0, Dec. 2009) using the latest (v 11....
13 years ago --- Quote Start --- Since you failed to get the systemID and timestamp, a quite simple thing to complete, there is something wrong with the cpu and memory system. I just figure out the same problem as you have. Here is my experience for reference. I checked my design carefully and found nothing doubtful, so I wondered why the cpu didn't respond to the PC. Oh, I forgot the reset signal and it was asserted forever by a switch. I flipped the switch and every thing worked. So, figure out why your cpu doesn't respond the systemID inquiry, then you can advance to the next step. --- Quote End --- yeah,I encountered this problem two weeks ago, today I figure it out , there is sth wrong with my reset setting, I FORGOT to assert a right reset button
