15 years agoError: Connected system ID hash not found on target at expected base address
Hello, Usual sentence first: I'm fairly new to FPGA programming, so bear with me. I tried to follow the Nios II Hardware Development Tutorial (version 3.0, Dec. 2009) using the latest (v 11....
15 years agoThe PDF is about a tutorial that doesn't involve the Nios II processor. I know that this would work as I had other verlilog designs running on the test board.
Having read the first thread I tried to download the .elf manually by typing: nios2-download -g count_binary.elf in the Nios II shell. Response: Pausig target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused The second thread contains an unanswered question of you.
