15 years agoError: Connected system ID hash not found on target at expected base address
Hello, Usual sentence first: I'm fairly new to FPGA programming, so bear with me. I tried to follow the Nios II Hardware Development Tutorial (version 3.0, Dec. 2009) using the latest (v 11....
15 years agoYeah, the pins are correct. I used this configuration for a simple verilog design and it worked. The sopc file is the one created during the tutorial.
Do you know where the "The system console model is invalid. Cannot launch." message comes from? The board or is it a communication error? Do you have a simpler programme that I could test? Just one LED or so? Maybe I'll try to write that myself.
