15 years agoError: Connected system ID hash not found on target at expected base address
Hello, Usual sentence first: I'm fairly new to FPGA programming, so bear with me. I tried to follow the Nios II Hardware Development Tutorial (version 3.0, Dec. 2009) using the latest (v 11....
15 years agoI understand it I was in the same situation a month back.
Are all the pin connections to the LEDs in the design correct.Verify from the board manual you would have got with the development kit.Because it is a sample design but may be not for your fpga chip pr board?Have you verified all the hardware connections are correct?Did you download the correct .sopc file with correct pin conigurations?Check in the pin planner.
