15 years agoError compiling BSP for Igor Opencores Macq
I'm trying to get a Cyclone II FPGA connected to a National Semiconductor DP83848 Evaluation kit to work. Struggled with it a bit and so far no luck. I'm trying to get the "Simple Socket Serve...
15 years agoUnder Nios-IDE you have to right-click on your project and select "System Library Properties". Then you see a window where you can change the RTOS the stdout and so on. Almost at the bottom of the window there is button called "Software Components". After you clicked it you should see the Nichestack options.
