15 years agoError compiling BSP for Igor Opencores Macq
I'm trying to get a Cyclone II FPGA connected to a National Semiconductor DP83848 Evaluation kit to work. Struggled with it a bit and so far no luck. I'm trying to get the "Simple Socket Serve...
15 years ago --- Quote Start --- Hello, ALT_INICHE should be defined automatically when you set "Add this software component" which can be found in the "System Library Properties" under "Software Components". --- Quote End --- I really appreciate your help but I can't seem to find the option that you are referring to. I've searched the BSP editor and I have selected properties for the BSP and for the project. I can see where to manually define things but I cannot find the option for "system library properties." I've searched the help files for "software component" and "system library" but I just am not seeing it. Am I missing something obvious? Thanks, David
