15 years agoError compiling BSP for Igor Opencores Macq
I'm trying to get a Cyclone II FPGA connected to a National Semiconductor DP83848 Evaluation kit to work. Struggled with it a bit and so far no luck. I'm trying to get the "Simple Socket Serve...
15 years agoHello,
ALT_INICHE should be defined automatically when you set "Add this software component" which can be found in the "System Library Properties" under "Software Components".
