20 years agoErasing/Programming EPCS via NIOS
I using a CYCLONE 1C12 with an EPCS 1C4 device. I have built a nios system and I am trying to download to my EPCS device via the JTAG. I have set the "Reset Address" to the EPCS_controller. I tried t...
10 years agoJust had this problem 10 years later. The solution is to specify the command correctly.
nios2-flash-programmer --epcs -base=0x00060800 --erase-all is wrong because -base looks to the programmer like -b at address "a". It should be (note --base): nios2-flash-programmer --epcs --base=0x00060800 --erase-all
