8 years agoEpcs16si8n eol
Hi Guys I see that EPCS16SI8N is being replaced by EPCQ16ASI8N. My boards are using a Cyclone III device so I am still using Quartus 13. Do you know if the new replacement part will work as a d...
8 years ago --- Quote Start --- Can anyone confirm that a EPCQ32ASI8N can be a compatible drop in replacement for a EPCS16SI8N for a Cyclone EP3C25? Thanks! --- Quote End --- Boffah, I can confirm that a EPCQ16ASI8N is a direct replacement for a EPCS16SI and it programs a EP3C16 fine. I didn't even need to regenerate the programming file Regards
