8 years agoEpcs16si8n eol
Hi Guys I see that EPCS16SI8N is being replaced by EPCQ16ASI8N. My boards are using a Cyclone III device so I am still using Quartus 13. Do you know if the new replacement part will work as a d...
8 years agoHi Martin,
Thanks for the reply it was very useful. I learned that I will have to disable the EPCS ID check when I convert the programming file to .POF. However what isn't obvious to me is what configuration device do I target? The pull down menu in Q13 doesn't have an option for EPCQA16. Do I leave the target as EPCS16 or EPCQ16? Thanks
