SERMASWATHIKA
Contributor
2 years agoepcs_signature_read_fail_error
Hi Team, when i tried to flash the FPGA with flash files using nios command shell, i am getting the following error, Please give solution for this.
wwanalim_intel
Contributor
2 years agoHi,
It seems the flash file setup programming is the only choice left now.
The quartus_pgm command method is also directed to the use of Nios II flash programmer which is already End of Life.
Thank you.
