16 years agoEPCS fpga+nios field update
Hi, I know this has been asked several times, but I can't seem to find an answer that fits my problem so here it goes: I have a large CIII design with a NIOS including the remote updat...
16 years agothanks, will have to try that tomorrow :)
What I did was to compare your files agains the standard ones in my altera installation. Since the standard ones are made for the stratix as well as the cyclone I assumed that I just needed to add your check routines for the safe and the user image to my file. Uncomment the altera standard ID checking. And then run a make together with my system.h and epcs base. This is properly not the most elegant way :rolleyes: -mitch
