16 years agoEPCS fpga+nios field update
Hi, I know this has been asked several times, but I can't seem to find an answer that fits my problem so here it goes: I have a large CIII design with a NIOS including the remote updat...
16 years agookay so I managed to create a boot loader based on yours which holds
safe image at 0x0000 page 0x0 user image at 0xe0000 page 0x0 My question is now; how do I get it into my design flow in order to create the base image with the safe image? I did the following: 'elf2flash --after=factory.flash --epcs --input=sw.elf --output=sw.flash --boot=fos_boot_loader_epcs.srec' which I programmed into the epcs, the factory firmware was loaded correctly! then I made the user firmware by: ' bin2flash --input=app_image.bin --output=app_image_flash --location=0xe0000' and programmed it to the epcs When I run the reconfiguration my factory fimrware is still loaded! -mitch
