16 years agoEPCS fpga+nios field update
Hi, I know this has been asked several times, but I can't seem to find an answer that fits my problem so here it goes: I have a large CIII design with a NIOS including the remote updat...
16 years agoIt's really not that bad. I can give you my modified bootloader if you want it but it's been hand-tweaked for my design and Stratix II GX. You could also post a new topic asking if anyone has a modified bootloader that they're willing to share.
But if you just want to have one image, I suggest using the script I've given above. This will create a single file that contains both your SOF and ELF files. Then you just program this file starting at address 0x0 in the flash. Jake
