17 years agoEPCS flash Programming error
I have just started a new project and I tried to download flashj and configuration data to my EPCS64N device. We are using a Cyclone III device. I received the following error. Does anyone know what ...
17 years agoActually, let me provide a bit more information to my post above.
Typically, I erase the flash first with this: nios2-flash-programmer --epcs --base=0x00000000 --instance=1 --erase-all and then program the hardware design with this: nios2-flash-programmer --epcs --base=0x00000000 --instance=1 ETF.flash and then add in the software design with this: nios2-flash-programmer --epcs --base=0x00000000 --instance=1 ETF_CPU1.flash When everything is working correctly, I get this output: <div class='quotetop'>QUOTE </div> --- Quote Start --- Erasing flash memory... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK Checksums took 0.0s 00000000 (0%): Erasing (takes a minute or two and eventually gets to 100% and tells me Erased 8192kB in xx.xs (xx.xkB/s) Programmed 0KB in 0.0s Did not attempt to verify device contents Leaving target processor paused . Downloading flash file for hardware... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK Checksummed/read 384kB in x.xs Erased 384kB in x.xs (xx.xkB/s) Programmed 367KB +17KB in x.xs (xx.xKB/s) Did not attempt to verify device contents Leaving target processor paused . Downloading flash file for software... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK Checksummed/read 64kB in x.xs Erased 64kB in x.xs (xx.xkB/s) Programmed 9KB +55KB in x.xs (xx.xKB/s) Did not attempt to verify device contents Leaving target processor paused[/b] --- Quote End --- Unfoturtunately, that's not what's happening anymore. Now I get: <div class='quotetop'>QUOTE </div> --- Quote Start --- Erasing flash memory... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK Checksums took 0.0s 00000000 (0%): Erasing (This time it just stays at 0% until jumping straight to completion after 10sec or so! Then tells me Erased 8192kB in xx.xs (xx.xkB/s) Programmed 0KB in 0.0s Did not attempt to verify device contents Leaving target processor paused . Dowloading flash file for hardware... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK No EPCS layout data - looking for section [EPCS-FF] Unable to use EPCS device Leaving target processor paused . Dowloading flash file for software... Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK No EPCS layout data - looking for section [EPCS-FF] Unable to use EPCS device Leaving target processor paused[/b] --- Quote End --- If I skip the erase step and jump right into programming, I get this: <div class='quotetop'>QUOTE </div> --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Resetting and pausing target processor: OK Checksummed/read 384kB in 9.6s Erased 384kB in 10.0s (38.4kB/s) Program failed Leaving target processor paused[/b] --- Quote End --- I would greatly appreciate it if anyone can help me determine what would cause this failure. Thanks!
