10 years agoEPCS controller clock
Hi, I have a NIOS2 Qsys design (ARRIA V, Q14.1) with an EPCS flash controller in it to copy the software from the serial FPGA configuration flash into DDR ram memory at power-up. This copy acti...
10 years agoThere is a work-around. You can add a serial flash loader IP to your design (through the Megawizard) and use the "Share ASMI interface with your design" option. That way you can program your EPCS with the Quartus programmer through JTAG, and access the pins from your design.
I've never tested it myself but it should work.
