20 years agoEPCS can't be THIS slow
I used the CycloneII dev-kit from altera for a project with uCLinux and a NiosII. To save some $$ I'm trying to configure the FPGA from the EPCS64 and load the kernel from the same EPCS64 thus el...
20 years agoHi Scott,
I'm at home now but couldn't stop thinking about the problem (I know, laugh as loud as you like) so I couldn't help but reading the forums.... First of: Thanks for those links you provided I think that excatly adresses my problem. I'll try it as soon as possible. I'll come in early tomorrow to try it out http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif I'll try and leave the bootloader out of the flash file 'cause what I now had was probably data from EPCS that got unpacked to RAM where the "second" bootloader kicked in to unpack my kernel from EPCS to RAM.... combine that with a EXTRA_DELAY parameter and you've got my weird problem... @jakobjones: It's not a big deal if the boot-time is a bit higher (but not minute)... And you know how managers are: "Hey don't you think you can loose the onboard ROM? That would save us a lot of money!" So I have to work with a slow EPSC http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Thanks all! Walter Goossens
