16 years agoEnhanced Interrupt API
alt_irq_interruptible() and alt_irq_non_interruptible() have been deprecated.
Are there equivalent functions available in the enhanced API or are these functions no longer needed because of the enhanced API? Thanks.3 Replies
I have the same problem!
There is a solution or I have to use the EIC? Thanks! - Altera_Forum
Same question here! I read the doc and still can't get a solution to make an ISR interruptible with IIC and Enhanced API. Or are all interrupts interruptible at default?
(Probably I didn't read it good enough or get the idea of how to make it interruptible) For a moment, I change the define ALT_ENHANCED_INTERRUPT_API_PRESENT in system.h manually to ALT_LEGACY_INTERRUPT_API_PRESENT. This is neccessary in order to use the old API. So just a workaround..... Any other solutions are appreciated here too! Thanks - Altera_Forum
We now implemented Altera's vic as External Interrupt Controller(eic). And now we can make use of the enhanced interrupt api.
If you use the vic you don't need to tell your ISR that it is interruptible by software anymore. You have to set the preemption options in the bsp in order to manage that interrupts are interruptible. So in your software you don't need to worry about calling alt_irq_interruptible() and alt_irq_non_interruptible() the right way. But I've only used the VIC for some days and will examine it a bit more......
