12 years agoEmulating AOCL on Windows: env command issue
First of all, I'm using Windows 64, and everything is okay when I compile and run the hello_example on the SoCKit. But, to avoid the important time that takes the aocl compilation and synthesis flow, I'm trying to use the emulator option. To do that: I managed successfully to execute the command "aoc -v -march=emulator device/hello_world.cl --board sockit", After that, I compiled, without any issue, the hello_world host program. But, when I try to run the command "env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=sockit hello", I get the following error message: env: hello: No such file or directory However, the file hello is there. Could you help me to find a solution to this problem ? Thanks and regards.1 Reply
you run this under admin access right?
