10 years agoELF file size issue from Nios II
Hi, I started learning FPGA. Bought MAX10 development kit which has 10M08SAE144C8GESE chip. I created basic system using Qsys guide. Imported qip file into Quartus and made a basic bsf file ...
10 years agoHello,
What other types of memory ( i.e SDRAM or DDR etc ) are available on your board? You should use that memory as program memory. In that case, you should be able to download 304KB of your code. Thanks, Bhaumik
