10 years agoElf file error
Hi , I am trying to run / debug my tse_tutorial ( triple speed ethernet ) in Eclipse . I did successful compile of Hw and also sw and when i tried to launch the appl from eclipse i got an error...
10 years ago --- Quote Start --- Hi, did you match this example with the default version(example platform) of the quartus and soc eds, and it's running up before? --- Quote End --- The example was made in the older version , i designed the whole SOPC system again in ver 13.0 and compiled it without any errors and downloaded it and then started making its software in Eclipse ver 13.0 as well . This is when i make a blank project and import this .C file which also compiles without errors and when i try to run i get this error ??? any clues ????
