10 years agoEDS QSPI programming problem
Hi, i’m using my custom Cyclone V SoC(5cseba5u19i7n) board in combination with QSPI flash (Micron 512Mbit).
I want to program the NOR flash via USB blaster with SoC EDS Command Shell version 15.0. When I start up the “SoC EDS Command Shell version 15.0”and type “quartus_hps.exe –c 1 –o PV ”. After programming done ,I get the following "1.send_access_data() error while accessing DP Register. 2.Debug Port Read Buffer reading failure, read_dp_buff() error while accessing AP Register.3.Failed to READ ACCESS to the Physical Reg. 4. Failed to read MPU Module Reset Register." I was wondering the JTAG was not nomally working. Thank you.3 Replies
--- Quote Start --- Hi, i’m using my custom Cyclone V SoC(5cseba5u19i7n) board in combination with QSPI flash (Micron 512Mbit). I want to program the NOR flash via USB blaster with SoC EDS Command Shell version 15.0. When I start up the “SoC EDS Command Shell version 15.0”and type “quartus_hps.exe –c 1 –o PV ”. After programming done ,I get the following "1.send_access_data() error while accessing DP Register. 2.Debug Port Read Buffer reading failure, read_dp_buff() error while accessing AP Register.3.Failed to READ ACCESS to the Physical Reg. 4. Failed to read MPU Module Reset Register." I was wondering the JTAG was not nomally working. Thank you. --- Quote End --- I am having the same problem. Have you found a resolution? - Altera_Forum
Have you found an answer to this? I am also having the same issue (5CSEBA4U)
Except mine says "Failed to release reset register of MPU" - Altera_Forum
Has anyone resolved this issue?
Thanks Kevin.
