10 years agoEDS QSPI programming problem
Hi, i’m using my custom Cyclone V SoC(5cseba5u19i7n) board in combination with QSPI flash (Micron 512Mbit). I want to program the NOR flash via USB blaster with SoC EDS Command Shell version 15.0....
10 years agoHave you found an answer to this? I am also having the same issue (5CSEBA4U)
Except mine says "Failed to release reset register of MPU"
